Hello! I have the Ortur LM2 Pro with the Ortur Rotary unit. Today I tried to install the rotary and it is not working.
I changed both machine settings to false
Plugged in the rotary to the proper cable
Went to “Setup rotary” and entered my roller and test piece diameters. *Didn’t know what math to use to figure the circumference but I read it should be in the low 60’s mm so I set at 63mm.
enabled rotary
Hit the test button and nothing happened. Tried the frame option and the same thing - nothing.
Looked at the notes and it is G-code locked out during alarm or jog state error #9.
So I uninstalled the rotary, changed machine settings to true and tried to do the frame option again and getting the same error message.
Where did I mess up?
Thanks
