SilkeV31
(Silke)
July 9, 2023, 10:19pm
1
Krijg constant zelfde foutmelding bij starten van laser:
Stream wordt gestart
Layer C00
Error:1
G-codewoorden bestaan uit een letter en een waarde. Letter is niet gevonden.
Op of nabij lijn 0:
Taak stopte
Stream voltooid in 0:00
Ok
Ok
Ok
Ok
Ok
Help aub!
ednisley
(Ed Nisley)
July 9, 2023, 10:47pm
2
This typically happens when G-Code clustering
is enabled in the Device Settings
for a GRBL controller that does not support it.
Make sure that option is turned Off
SilkeV31
(Silke)
July 10, 2023, 8:17am
3
Even then i got that issue
JTR
(Tyler Raps)
July 10, 2023, 2:20pm
4
Another common cause of this is having your device set to the incorrect device type. Check to make sure it’s set to GRBL.
-Click “Devices” in the ‘Laser’ window
-Double click your laser in the list
-Make sure the selected device is ‘GRBL’
-click next until you’re done
SilkeV31
(Silke)
July 23, 2023, 12:42am
5
Werkt niet
Doesnt work either
system
(system)
Closed
August 22, 2023, 12:43am
6
