Galvo engraving alignment issue top of letters
Hi all,
I recently switched from 1.7 to the latest 2.1 on my JCZ fiber. I can’t categorically say its since I made this software change but im seeing strange behaviour which I didn’t notice before.
This lead to me going through the stages of tuning the parameters, On/Off, delays etc.
Some of the delays seem to work inversely to me. Having too long of a delay causing a worse engrave but I finally got everything dialled in.
For a final test I then just engraved abcdefghijlmnopqrstuvwxyz123456789 across the field.
The timing for the top of the letters is terrible and gets worse the more I increase the fill. The fill on the right of the image is 0.03mm.
I tried 47 variations of different settings, adjusting all the delays etc and I cant seem to home in on how to fix this issue. For reference im engraving at 2000mm/s which is my normal for anodised but also have exactly the same offset and effect at 1000mm/s.
Any advice of what to try next!
I’ve never seen anything like that before - it looks like it’s scaling differently on different layers, which is not something LightBurn even supports.
Is the engraving running diagonally like the pictures are showing?
How old is the machine? To me this looks like a failing scanhead power supply - they start to move funny, and over time it gets worse.
It would be a simple test to restore version 1.7.08 and see if it still does the same thing. If it does, that would rule out the update as an issue. You could also do the driver swap and try some runs in EZCad - if the problem shows there too, it would rule out software altogether.
Good idea on checking other software - just reinstalled EzCAD2 and I have the same issue so im fairly certain I have a hardware issue.
My power supply is a multi output type - have just over 15v on the power supply so hard to tell. Guess will have to look at both a different power supply and head to try.
System is around 2 years old.
