Galvo framing outline stops showing
I have a BMW 50 watt fiber running from a Windows 11 PC. running LB LightBurn 1.7.00, built Thu 2024-03-14 @ 15:42
I am in the middle of making a 100 keychains to fill an order. It is a very simple object, just a 1.4 inch circle (as a tool layer) and a Text string in Times New Roman font centered in the circle.
The first 5 or six key chains the framing worked as expected. I would place the new keychain down click the frame button and the rectangular frame would appear (I have the Image Bounds selected and all other options not selected)
After the keychain was marked I would close the framing window, remove the freshly marked keychain and place a new on on the workspace.
Then click the Frame button and do it all again. After the 5th keychain the red framing square stopped appearing. I closed and reopened the framing window, I checked new options for framing, I unselected and reselected the objects. Nothing. left the laser turned on and did something else for about 10 minutes and then came back and when I clicked Frame, the red rectangle appeared again.
Any ideas about what’s going on?
