I’m seeing that a lot of what you can do with a MOPA depends on the galvo head capabilities.
I have a SG7110 and most often raster at 7000mm/sec on an FL160 110mmx110mm, which is about the max speed I can go.
I can command it faster, but then you start to see overburning on the line starts because the mirrors aren’t quite up to the commanded speed.
Actually some of the quality problems I still have may well be due to this still being more significant than I realized.
Going slower requires proportionately reducing the frequency to avoid melting the surface, but that really digs into the runtime.
I’ve wanted to get an SG7210 head which is supposed to be an upgrade but I’m a little confused because I see there are A,B, and C suffixes, and no suffix. I just got in one which was supposed to have silicon mirrors but the badge said K9 mirrors, which is not advised for my 300W MOPA as they have poor thermal conductivity and can heat up and expand. Maybe won’t happen while holding back the wattage so I don’t melt the coin, but it would make the machine fail whenever I do engage the full power so probably not an upgrade. I had to return it without trying it.
I can see that, for the same galvo head, if I change from a 110x110 field to a 200x200 field lens, the mm/s capability should nearly double, and reduce for a smaller field lens, because the mirrors actually only know the angular speed, they don’t care what the lens does with it after to make a linear surface speed out of it. But a larger field lens has a proportionately larger spot size- but that may actually help if the spot size is smaller than you need for the detail level in your work. Switching to a 200x200 would not only go 2x the speed, but you’d double the line interval and take 1/2 the number lines per pass, so 4x faster speed.
Anyhow, point being, I see there’s a limited number of 10mm aperture plug-and-play galvo heads here, and I likely have “the low end”, SG7210 is “+100 more than” an SG7110, but the specs for AliExpress SG7210 head ads go ALL over the place and I don’t know if it’s because of the A/B/C/(null) suffix, or if silicon mirrors might be heavier and fundamentally slower, or if their “max marking speed” makes no sense at all because it doesn’t specify it in angular units OR specify the lens size used to get that surface mm/sec figure.
This is a very frustrating market- I’m not sure I’ll find anyone here who has upgraded to even one other head on the same machine, thus have actually seen the difference. Pretty much given up hope of finding anything really comprehensive like comparing ALL the heads on the same MOPA with the same lens.
