Galvo laser lasers same file in different position and size after upgrading from 1.2.01 to 1.7.04
Hi,
I recently renewed my licence and upgraded from 1.2.01 to 1.7.04 in order to take advantage of some features that have been introduced since then. However, after upgrading, I discovered that the same project files I’ve always used cause my Galvo laser to frame and fire in a different position and size than they used to - notably, smaller in size and to the south west of where it is meant to be. In order to restore the intended size and position in 1.7.04, I have to reposition and resize items in my files to proportions that no longer match their real life size.
I installed 1.2.04 as a test and found that the project files behaved as normal once again, but I can reliably replicate this issue in 1.7.04. I have not yet narrowed down the exact version that causes the project files to be translated into Galvo instructions incorrectly.
Having two separate versions of Lightburn installed to get around this issue is not ideal. Is there a known change somewhere between 1.2.04 and 1.7.04 that would be causing this?
