I toggled output on several items and saved each as it’s own gcode file. (I run a jtech 44w on a onefinity cnc which is a grbl based controller vs a directly controller unit.)
When I ran the text separate from the outline cut file the text was shifted down and left from where it is when I export all components as one file. How do I avoid this?
I guess you have different origins because you used some specific setting with the “start from” option and “cut selected graphics” and “use selection origin”. Especially the latter will shift the origin depending on what you selected. Observe the green square that is shown in the workspace.
