Not sure whether I got the category right, pls. bear with me.
So, I am using my CNC-Step Router with a Laser module attached to run it as laser engraver.
As the KineticNC (aka Beamicon) controller does not seem to be supported by lightburn, I set up my machine as GRBL device and save the G-Code instead of feeding it directly. This approach works pretty well when engraving images by scanning back and forth.
However, I have a problem when engraving vectors (e.g. Text) as the laser is not turned off when moving from one shape to the next, leaving marks on the space between.
I read that for GRBL based systems, this behavior can be controlled using $32=1
Unfortunately my controller is not GRBL based so I need another way to turn off the Laser in between shapes. Two solutions come to my mind:
Request a feature that would allow adding extra G-Code commands to be executed when moving (e.g. Turn off Laser, Move to next shape, turn on Laser again), similar to the setup where I can define header and footer of the G-Code
Create a post processor that adds such sequence to the G-Code generated by Lightburn after storing the G-Code.
Option two would require to identify any “movement between shapes” when parsing the G-Code to insert the code at the right place.
Does anyone have an idea how I could identify this?
Regards,
Tom
