I fired up Lightburn today and all the gcode files I’m generating are all the same size of 191 bytes and only contain the following code:
; LightBurn 1.0.04
; GRBL-M3 (1.1e or earlier) device profile, absolute coords
; Bounds: X0 Y0 to X0 Y0
G00 G17 G40 G21 G54
G90
M5
M9
G1S0
G90
; return to user-defined finish pos
G0 X0 Y0
M2
I don’t recall changing any settings that could cause this output to be modified, so I loaded previous working files and tried saving their gcode again only to generate the same 191 byte files. Can someone assist?
Enable ´Out of Bounds´ warning as a preventive measure if your OF has a 815 x 1222 mm and your shape as a width of 819.392 it wont be sent to the laser/GCode.
Report back with the dimensions please.
I think I figured it out. For some reason, the start from position was changed to Absolute instead of User Origin. I switched it back to User Origin and now I can see it on the preview and the Gcode file is more than 191 bytes.
