the generated code has no arcs (gcode G2 & G3), the arcs are a sequence of small straight lines in thousandths of a mm, some machines can’t handle this well. Is it possible that the code is generated with arcs and perhaps with less decimal places example 1/100mm?
example gcode two small 10mm diameter circles
M3 S650
G0X0.259Y5.242
G0Z1.000
G3X5.259Y0.242I5.000J0.000F600.0
G3X10.259Y5.242I0.000J5.000
G3X5.259Y10.242I-5.000J0.000
G3X0.259Y5.242I0.000J-5.000
G0X10.491
G3X15.491Y0.242I5.000J0.000F600.0
G3X20.491Y5.242I0.000J5.000
G3X15.491Y10.242I-5.000J0.000
G3X10.491Y5.242I0.000J-5.000
G0X0.000Y0.000
M5
same example Lightburn gcode without arcs: (two small 10mm diameter circles)
; LightBurn 1.2.01
; GRBL device profile, absolute coords
; Bounds: X1 Y1 to X21.23 Y11
G00 G17 G40 G21 G54
G90
M4
; Cut @ 800 mm/min, 60% power
M8
G0 X3.204Y1.854
M3
; Layer C00
G1 X3.617Y1.603S600F800
G1 X4.054Y1.393
G1 X4.513Y1.225
G1 X4.992Y1.102
G1 X5.489Y1.026
G1 X6Y1
G1 X6.511Y1.026
G1 X7.008Y1.102
G1 X7.487Y1.225
G1 X7.946Y1.393
G1 X8.383Y1.603
G1 X8.795Y1.854
G1 X9.18Y2.142
G1 X9.535Y2.464
G1 X9.858Y2.82
G1 X10.146Y3.204
G1 X10.396Y3.617
G1 X10.607Y4.054
G1 X10.775Y4.513
G1 X10.898Y4.992
G1 X10.974Y5.489
G1 X11Y6
G1 X10.974Y6.511
G1 X10.898Y7.008
G1 X10.775Y7.487
G1 X10.607Y7.946
G1 X10.396Y8.383
G1 X10.146Y8.796
G1 X9.858Y9.18
G1 X9.535Y9.536
G1 X9.18Y9.858
G1 X8.795Y10.146
G1 X8.383Y10.397
G1 X7.946Y10.607
G1 X7.487Y10.775
G1 X7.008Y10.898
G1 X6.511Y10.974
G1 X6Y11
G1 X5.489Y10.974
G1 X4.992Y10.898
G1 X4.513Y10.775
G1 X4.054Y10.607
G1 X3.617Y10.397
G1 X3.204Y10.146
G1 X2.82Y9.858
G1 X2.464Y9.536
G1 X2.142Y9.18
G1 X1.854Y8.796
G1 X1.603Y8.383
G1 X1.393Y7.946
G1 X1.225Y7.487
G1 X1.102Y7.008
G1 X1.026Y6.511
G1 X1Y6
G1 X1.026Y5.489
G1 X1.102Y4.992
G1 X1.225Y4.513
G1 X1.393Y4.054
G1 X1.603Y3.617
G1 X1.854Y3.204
G1 X2.142Y2.82
G1 X2.464Y2.464
G1 X2.82Y2.142
G1 X3.204Y1.854
G0 X11.835Y3.617
G1 X12.085Y3.204
G1 X12.373Y2.82
G1 X12.696Y2.464
G1 X13.051Y2.142
G1 X13.436Y1.854
G1 X13.848Y1.603
G1 X14.285Y1.393
G1 X14.744Y1.225
G1 X15.223Y1.102
G1 X15.72Y1.026
G1 X16.231Y1
G1 X16.742Y1.026
G1 X17.239Y1.102
G1 X17.718Y1.225
G1 X18.177Y1.393
G1 X18.614Y1.603
G1 X19.027Y1.854
G1 X19.411Y2.142
G1 X19.767Y2.464
G1 X20.089Y2.82
G1 X20.377Y3.204
G1 X20.628Y3.617
G1 X20.838Y4.054
G1 X21.006Y4.513
G1 X21.129Y4.992
G1 X21.205Y5.489
G1 X21.231Y6
G1 X21.205Y6.511
G1 X21.129Y7.008
G1 X21.006Y7.487
G1 X20.838Y7.946
G1 X20.628Y8.383
G1 X20.377Y8.796
G1 X20.089Y9.18
G1 X19.767Y9.536
G1 X19.411Y9.858
G1 X19.027Y10.146
G1 X18.614Y10.397
G1 X18.177Y10.607
G1 X17.718Y10.775
G1 X17.239Y10.898
G1 X16.742Y10.974
G1 X16.231Y11
G1 X15.72Y10.974
G1 X15.223Y10.898
G1 X14.744Y10.775
G1 X14.285Y10.607
G1 X13.848Y10.397
G1 X13.436Y10.146
G1 X13.051Y9.858
G1 X12.696Y9.536
G1 X12.373Y9.18
G1 X12.085Y8.796
G1 X11.835Y8.383
G1 X11.624Y7.946
G1 X11.456Y7.487
G1 X11.333Y7.008
G1 X11.257Y6.511
G1 X11.231Y6
G1 X11.257Y5.489
G1 X11.333Y4.992
G1 X11.456Y4.513
G1 X11.624Y4.054
G1 X11.835Y3.617
M9
G1 S0
M5
G90
; return to user-defined finish pos
G0 X50 Y0
M2
