Hello, is there a way to get the machine to go to the corner exactly when you press home. Mine is off by a few mm.
The limit sensors determine where the edge of the bed is located. My sensors do not have any adjustment capability, other than a bit of vertical (and not much). I had to add a plate to my trigger to compensate for the lack of vertical adjustment in my recent sensor change (rather than order the “more correct” sensor) and in the process, moved the new plate outward a few mm.
You could do something similar that would extend the sensor plate by the desired amount. Depending on the design of your existing trigger plate, you’d not have to increase the thickness. Experimentation is indicated.
