get position in 0.9.10 Does not return correct position in units selected.
Is your laser at X:1" Y:1" ?
There’s a setting in GRBL that controls the units that the laser reports in. LigthBurn assumes that setting is in mm.
$13=0 : https://github.com/gnea/grbl/wiki/Grbl-v1.1-Configuration#13---report-inches-boolean
All OK. Have used GRBL Panel for 4 years and have always set $13=1 for it to report inches on the display. I don’t understand why if I have $13=0 it now shows inches on Move screen but mm on the Console screen.
It’s LightBurn assumes the controller is reporting mm (the default) and converts the numbers internally to whatever you have the display set to.
