How do I reset lightburn to default settings?
What values do you want to reset?
Ive lost the box with all the settings to frame, sent, origin, etc.
Under the window tab there is a reset to default on top. You can also start lightburn while holding the shift key.
Also under the window tab make sure there is a checkmark next to laser for that window.
Shift key worked… Thank you.
