Has anyone been able to use the primary laser on the D1 for framing while using Lightburn.
It works while using LaserBox Basic.
Thanks,
Joel
Thanks,
Joel
There was a user that was using the primary laser on his D1 instead of the crosshairs because they had not been turning on initially. So it’s possible and in reality, there’s no reason why it would work any differently from other lasers. The framing function is using the same mechanisms as any other burn, just at typically lower power and higher speeds.
Hi. I’m still trying to figure out Lightburn. Are you trying to turn on the focus beam, not the crosshairs, like you can in LaserBox? I use the beam, not the crosshairs and I am able to turn my beam on by going to the Move Window, then click on Fire (and you can set the beam power similar to Laserbox). I hope this helps.
