Anybody using a OMTech 50w CO2 or similar laser have any good starting points to get good photo engravings into glass? I seem to be chasing my tail endlessly. Or where the DPI diminishing return point is. So far this has gotten me the best results, but could still use improvement.
Have you tried running an interval test? That will tell you the upper bounds of resolution you can reasonably expect. Going beyond that won’t improve resolution but may get you a particular look that you’re going for.
Go to Laser Tools->Interval Test. You may want to try this first on some non-precious material so that you know how it behaves. Then you can try this on your target material.
