Good evening, I have a file with a broken line and when passing it to the program a continuous line is made.
What can I do to solve this problem.
Thank you
Sounds like the attribute is being ignored. Are you able to replace the line with the ‘broken’ attribute with a number of discrete short lines?
Another possibility might be that the rendering scale of the line breaks might be different between the software used to create it and LB, and if you zoom in close enough it will look broken again. If so, could you use the original software to change the line to be much more coarse?
It’s probably related to how it’s imported or how your ‘other’ program creates the end product.
It might be nice if you could post the files…if possible…
Maybe put that line on a tool layer
