Grabado y corte distorsionado
Tengo una sculpfun s30 y mientras tenia el periodo de prueba todo quedaba bien, ahora que tengo la licencia todos los cortes y grabados no se realizan bien, como se podra solucionar
“I have a sculpfun s30 and while I had the trial period everything was fine, now that I have the license all the cuts and engravings are not done correctly, how can it be solved?”
There is no difference between the Trial and Licensed versions.
a setting or two may have been ignored, especially if you installed a new copy of Lightburn.
  1. Make sure the $30 GRBL parameter and the Device Settings S-value max are the same (typically 1000).
  2. Make sure you have the correct Device (lower right in Laser Window) selected.
  3. Confirm that your speed and power parameters are what you need them to be for your project.
I agree with what Mike said.
Show some pictures of your settings and the result, than it’s possible to help.
