Depuis les dernières mises à jour le mode remplissage ne fonctionne plus.
Si quelqu’un a idée cela serait bien.
Merci
Which update?
“Fill mode does not work anymore” is kind of vague. Can you give a better description of what is not working? What are you expecting it to do and it is not doing it?
If you import a jpg or png, there is no fill mode available since it’s an image then. Images are images. If you convert it to vectors (trace image), then you can use the fill mode as well.
