I’m trying to get my machine to print a gray scale image. I seem to be having an issue getting the setting dialed in?? When I printed a scale test it seemed to be a failure.
My machine is
MPCNC machine
Rambo board 1.3
Running Marlin firmware
J Tech Photonic 4.8 watt laser
When I run a test program it is only printing at the 100% power and doesn’t seem to translate any of the gray scale in.
here is the result of lowering the speed to 50mm/s at top speed and 10mm/s at the low speed. It gave a better result. But shouldn’t I be aiming for cleaner look from the test or is this a good result?
Have you ever done a ramp test, focus check, or verified your focus distance is accurate? This looks like a focus issue to me - your text should be much more crisp than it is.
