Just setup a wheeled rotary axis on my X-Carve. I’m running a Demon Controller with rotary switch by Phil Johnson/Designs by Phil. He recommends using GRBL 1.0c which I installed.
When I initially setup Lightburn for my X-Carve w/ the X-Controller with 1.1f or g, I set it up as a GRBL Laser.
Seems to work OK but a little hot. Had to dial down the 'Fire" feature to 2%. Should I set it up again as a GRBL-M3 device?
