Hello, i have a problem, if i run a job in lightbrurn the steppers of all axis is controlled to hold the positions. But when i normaly work in lightburn to plan a job the axis are out of any break funktion. So my z-axis with my lasermodule sometimes slowly comes down to the worktable.
Is there a funktion, to use, that the motors permanent in “breake modus” ?
From the title, I suspect you are using grbl. You can set $1=255 to have the motors powered all the time. They will never get de-energized then.
Thanks, that solve my Problem…
