Air assist is usually M8 and M9. If M9 does not turn off the port for you, you might need a pull-down resistor on the port. LightBurn is emitting the commands correctly - here are three small shapes, with the first and last using air assist, and the middle one not:
You can see an M8 / M9 pair around both the first layer and the last layer, so air assist is turned on for the first layer, off for the 2nd, on again for the 3rd, then off at the end of the file.
Thanks you for your support.
The problemm is solved.
In the GRBL LPC in time, there is a bug.
Some freinds have the for me the code debug and new compiled.
Today i have no problems with the debugt firmware version.
