I modified a vinyl cutter with arduino nano and grbl1.1. Problem is that the Z-axis ( drag knive) is controled by a solenoid and does not lower or retract automaticaly. Z1 and Z0 lowers fine when giving manual command. PS. I did modify the grbl code for Z to remain low during X and Y movements and works fine as tested. also $32=1
. regards
