Green Origin Dot Issue
Good morning,
I can’t seem to get the little green origin dot to move from the home position past 2 inches positive direction in the X and Y. It will move around within the 2 inches and into negative positions but not beyond the 2 inch square. I have the laser mounted on a router machine. The machine area is defined. I’m using the Openbuilds X32 controller so I use the Control software for router and Lightburn for the laser. Everything works ok except I’m stuck using that origin for all my laser work. I think it should be able to be positioned anywhere in the machine area with the User Defined option selected? Clear origin and set origin doesn’t seem to affect it either.
Is this for a specific project, or any project? It sounds like you have a very small graphic around +2 inches in X and Y, which is being included in calculating origin.
If you enable Cut Selected Graphics and Use Selection Origin and select only the graphic you want to engrave, does the green dot move? If so, there’s definitely a tiny graphic that’s causing this.
That was it!
Thank you so much!
Dave
