Grid Smaller Than Cooordinates
I added this project downloaded from this site, the coordinates are correct but the grid is small. What am I missing please?
Can you specify the problem? Is it the dimension of your workpieces that is too large in relation to your machine dimension?
The grid is the size of the working area of your laser. (320mm x 200mm from what I can tell)
Hi, the bed size is 508X305mm which is the Thunder Bolt Laser
Where as the coordinates are much smaller.
If your working area is 508 x 305 (as per the Bolt’s website page) then you’ll want to go to Laser Tools > Device Settings and update your work space size to be correct. Device Settings: Dimensions / Units - LightBurn User Guide
Thank You Colin, big help that .. :+1:
