Group out of focus
I run parts of file out of focus but keeps adjusting focus for each item. I have grouped them but does not fix the issue. I want it to run all the out of focus lines together and focus only once for this action. Any advice?
What type of work are you doing with the “out of focus” bits, Line or Fill?
The following is worth review:
In particular,
Order By Groups
If you choose Order By groups the cut planner will apply all remaining optimizations to all the objects in a root-level group, then the next Grouped object, and so on. Objects not part of a group are treated as being in a group together.
I am using both line and fill. When I get back to the shop I will go over the settings you sent over. Thanks.
For Fill work, you can also leverage these options to assist in controlling the order of production.
