Is there an option in LB so that you can group the colored layer without going through the whole job and picking each individual item assigned to that color
Edit → Select all shapes in current cut layer
Presto!
You can also hold down the Shift key, and click on the layer you want to select everything in in the Cuts/Layers window. This will select all of the items on the screen in that layer.
Thank you guys very much. Big help
