Gweike cloud 55 w pro offset fill
Hi i have a question about offset fill on gweike cloud 55w pro
there is a big difference i time to engrave a 200mm circle with 2 mm offset compared to fill , it was about 25 min depending on settings. with my machine using offset fill with any kind of speed say 400mm / sec my offset just draws spirals and seems to grind a bit maybe jump a tooth, and as i slow down the speed to try to improve this say 100mm/sec it still does it at a reduced amout, I contacted Gweike cloud on whats app they said the machine does not support offset fill , I can do a hex shape the same size in offset fill at 200 mm/ sec no problem , I just wanted a second opinion if anyone has one, I ended up not using offset fill and the job came out perfect although it took a lot longer, see pictures for an example. thanks
bottom pic is design top pic is results
