I’ve tried various test cards already with different line intervals from .1mm to .05mm and different air pressures. My threshold is 11% power which I’m guessing is basically 17watt’s.
Hi , yes is the short answer.
I have 130w but its close enough to yours.
I actually tried on two machines;
a 25 watt Epilog and my 130 watt.
The detail was better on the Epilog but its fitted with a 2 inch lens so no surprise there but the 130W did a good job also I just picked up the speed a little to reduce the burn.
What are your results like ?
Here’s a couple of mine
I haven’t really started the engravings yet because I’m just burning through it at 500mms and 15% power.
Maybe when you prepare an image and start burning dots and not constant power, you will see a big difference
My last laser was a small A4 K40type, and I used to cut leatherette or pleather etc.
Just be careful, the fumes can be toxic and it will cause some corrosion on some metals.
I found this to my cost .
