Have problem with x70 max
Hello i have atomstack X70 max. but I have a problem. I make a square with dimensions 50/50 the machine makes 50/70. How do I correct it?
Did you adjust any of your firmware settings?
If not, I would perform some maintenance to rule out mechanical issues as the cause:
I will try now
and noting
Any chance you have the Rotary checked?
Rotary is turned off
Is this a new issue? In Device Settings > Working Size what is your Width and Height set for. Is it possible you have the numbers switched?
The size of the A70 Max is 850 mm x 800 mm. I believe it is longer front to back than it is wide. So in device setup X axis (Width) should be 800 mm and Y axis (Length) should be 850 mm
If that looks ok instead of a box try just making a vertical line and a horizontal line both 50 mm and see what happens.
I assume your using LightBurn. Download a copy of LaserGRBL and try the same test there and see what happens. If it works there then that eliminates your machine as the issue
In the Console type $$ then press enter. Copy & Paste all the ourput here.
Problem solved. After command ‘$rst=*’ all work normal
