Hello,
I have a sainsmart 3018 prover with extended rails. it has a 5500mw Blue/iolet laser.
I had it running and had the travel lines burning.
I got the travel lines to not burn, but the laser was on and not burning anything.
Then I did the new update.
While trying to find the $$ codes that I needed and suggested, things got worse.
I uninstalled everything, reinstalled, still no good.
More and more topics of what the settings are and now the machine won’t move at all.
These are what the settings are currently. can anyone help?
$0=10
$1=25
$2=0
$3=96
$4=1
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=1
$20=1
$21=0
$22=1
$23=96
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
And it is giving me this response when I try to start.
Project loaded in 22 milliseconds
<Idle|MPos:0.0000,0.0000,-0.0394|FS:0.0,0|Pn:XYZ|WCO:-6.0500,-4.1170,-0.0780>
ok
Starting stream
Layer C16
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the 'Devices' button to reset the connection)
On or near line 4:
Job halted
Stream completed in 0:00
[MSG:Reset to continue]
ok
Grbl 1.1f ['$' for help]
[MSG:'$H'|'$X' to unlock]
[MSG:Caution: Unlocked]
ok
Thank you in advance.
