When I try to us the rotary tool in lightburn. When I go to frame it the rotary keeps turning the cup for 4 complete rounds. then does the same going back. The image is only 2.9 height 1.73 width. I tried using both rotary tools I have and they both do the same thing. I have a Xtool d1 pro 20w with the RA2 rotary as well as the older rotary tool from xtools. any help would be great.
Did you set the correct rotary parameters ? RA2 uses 128mm per rotation for Chuck or 32mm per rotation and 17mm Roller Diameter for Roller.
