I have lightburn on my desktop and for some reason even though I set the origin of my design for center, when I actually run the design the laser moves to the back corner of the engraving bed and traces the image from the left bottom corner. I’m using a laguna 150w c02 laser.
Even if I move the laser and hit “origin” when I press “frame” the laser moves to a different location.
Also it only does it on this particular project. My other engravings are set to center origin and the machine does it centered.
What is the ‘Start From’ setting in the file set to? It sounds like it’s probably “Absolute Coords” instead of “User Origin”: Coordinates and Job Origin - LightBurn Software Documentation
Thank you, I will check that
