Having trouble with framing
when i try to frame an image i can put the image in the middle of the the work area and it wants to frame in the bottom left hand corner or if i move it to the right bottom corner it still frames to the bottom left corner can anyone help i have a sculpfun 33watt utral with a 600mm x600mm work area
You have your Start From set to current position. It will frame from where the laser head is currently sitting. If you want it to frame somewhere else you need to move the laser head first. Your green job origin dot is located at the bottom left of your graphic. That can be changed by using the 9 dots in the laser window below the start from dialog.
This video of mine may help your understanding.
