Good Afternoon, I am having trouble setting up my Laser. I did the initial set up, however whenever I plug it in, it goes into the right corner and tries to move more and stops. I am getting the following error. Any help is appreciated, thank you!
Waiting for connection…
ok
[VER:1.1h.2022011001:]
[OPT:VZ,15,128]
Target buffer size found
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
Can you confirm if your machine has homing switches or not? I was under the impression that it didn’t. However, you have homing enabled ($22=1) which is why it’s trying to home. Did you change this parameter?
If your machine did have homing it would move to the front-left of the machine. Did you change any parameters for homing direction? If not, is it possible that your machine is turned 180 degrees from what it should be?
Hello, thank you for the reply. I am very green to this am currently running at Atomstack A5 Pro. Would you be able to guide me to see if it does? On the initial set up, it called 410 x 400, I changed to 390 x 390 because it kept moving forward. Should I disable the autohome function upon initial set up?
