Hello — I have a Genmitsu PROVerXL 4030 with a LaserTree module.
When I power on the machine, the laser output gives a fixed voltage of about 5 V (the laser stays on or doesn’t respond to PWM changes).
I’ve already tried:
- Checking the wiring (3-pin cable),
- Sending commands
M3 S255/M3 S0, - Checking the SainSmart documentation (the “disable PWM” switch is set to OFF).
Symptoms: The PWM voltage does not change when I send S0 → S255 (it always stays around 5 V).
What I measured: (please see multimeter readings, GRBL version, exact wiring, connector photo if needed).
Has anyone experienced this before?
Any ideas — wrong cable, converter/inverter between the board and the laser, dead PWM pin, or GRBL parameter to check?
Thanks ![]()
