hello, I was wondering if anyone has an Atomstack S20 pro laser and if they know if it cuts acrylic 3mm and engraves
thank you for the answer and have a nice day
Hello,
The atomstack s20 is a diode laser which uses a blue light laser in the visible range of 450nm. As such it will pass directly through clear materials and no energy from the laser will be absorbed as heat = no cutting transparent acrylic, or any acrylic that reflects the photons of the same frequency such as blue, dark blue, or purple. It will also have trouble cutting opaque acrylic such as white which reflects most colors.of visible light.
It should be able to cut opaque black acrylic, red, yellow.
If you want to cut clear or transparent acrylic you should look at a co2 laser which emits a beam at the 10,000nm~ range which is in the non visible infrared spectrum.
