In the preview window, when using the “start here” button (I have the Current position selected in the Start from box), Will the Job Origin be the same when I want to touch up an area?
Apologize, using version 1.7.04
That depends on whre your laser goes when it’s finished. If it returns to the starting position there is a chance that it will go back over the same path. If you have a go to on finish position, or if it stays where it stopped then it definitely will not be repeatable. Either use user origin and set an origin point or use absolute coordinates. You must be sure that nothing has moved between runs.
Thank you!
