Hello when I cut wood engraved lines appear the paths of the laser
hello when I cut wood engraved lines appear the paths of the laser
This is typically from laser mode not being enabled ($32=1). Can you check Edit->Machine Settings to confirm?
This is usually caused by the $32 variable set to 0. It needs to be in laser mode, so it turns the laser off between cuts…
A spindle isn’t turned off between operations … like you do with a laser.
Enter $32=1 in the console and see if that fixes your issue.
You should follow the Lightburn Setup for GRBL… this is noted.
Good luck
thank you I will test as soon as possible I find where the value is located
hi thanks good perfect
