Hi,
I have a Jindiao JD4060 DSP laser and have been using LaserCut5. 3 but I use Lightburn on my small laser and want to upgrade the JD4060,
when I get Laserburn to try and find the JD4060 it doesn’t but lasercut 5.3 works fine using USB
Device manager sees the USB port as … LT Slave USB(68013A)
help please… then i can buy the DSP version…
If your machine runs on LaserCut it’s likely using a Leetro controller which is not supported in LightBurn.
Can you take a look at your controller to confirm?
Hi, yes it’s a Leetro MPC 6525
Is a controller swap a viable option for you?
