Hello I have a C02 laser and I’m trying to cut circles on ABS guitar pickup covers but I’m getting gummy, bead-like edges. I’m aware that is not recommended to cut ABS with laser but many big companies do and they get clean cuts. What would be your setting recommendations for clean cuts? Thanks in advance. (Picture provided)
I cut 2mm ABS occasionally at 18mm/s, 25% power (5mA). (60Watt CO2)
For better cleaning afterwards, I cover the entire area, on both sides, with normal dishwashing liquid, not diluted, with my fingers or a sponge.
Is that one pass only? Thanks in advance
yes, it’s just a single pass
I usually cover ABS with adhesive paper. The beads end up on the paper and can be torn away together with the paper. But that is for cutting only. I did engrave it, but it was rather tricky to get it well. V500, P25 (110W laser) and DPI = 500 worked for me. Your DPI settings may be quite important
Keep in mind that the actual speed on small shapes like those circles will be much slower than the LightBurn layer speed: the laser head cannot accelerate hard enough to reach the layer speed along the very short lines making up the circle.
A 'Material Test` covering a broad range of speeds and powers will show the small group of workable cutting combinations.
Within the limited range of speeds available for small shapes, the only real control will be the laser power. Dialing it down to the minimum required to make the cut will (probably) produce the best results.
Larger shape may cut cleaner, because the laser can reach higher speeds on longer vectors.
Mostly due to ABS having a low melting point and very low glass temperature producing the gummy mess you’ve encountered, rather than producing any particularly toxic / corrosive gases.
I think it would be helpful to update your profile, pain, but you’re missing some vital information that could help us help you.
You profile states an AtomStack P7 40, which appears to be an led type.
You started out with I have a co2, you didn’t advise us of it’s power or what controller it has.
All of these can help us help you. Using a Ruida controller things are handled one way, a grbl machine another. Even being a co2 doesn’t mean it’s not grbl.
Things like speed, as @ednisley mentioned is only a guess unless we have more information, although I think Ed usually knows what he’s talking about. There is also min/max power settings, all of this influences how we interpret a good answer or a guess.
