For some reason today, uploaded images i have engraved before are all creating error 1 command letter. The laser starts and about 3 seconds later stops engraving.
A screenshot of the error, context of what you’re doing, and any description of what you observe during this process would be helpful. Has anything changed since before this issue began?
On a hunch, can you check Edit->Device Setting->Gcode tab. Is there anything populated there? If there is but was not intentional, then remove all content and test again.
type the following into the console:
then hit enter.
if you type the following:
you will get the error and no help.
If you scroll back in the Console window you may find the error message and if possible copy/paste/share some of those words with us.
