Help help help X axis
i klikk the x + machine moving right side and after klikk x - machine movin same right side.
whay ???
I’m very tired of this.
I I use 3 identical motors (nema17), the Y axis works perfectly in all directions.
I also checked the wiring of the motors several times with measurements.
I don’t know what causes this.
Can you switch connectors between X and Y at the controller?
From your last post you replaced controller and was X moving left and right then?
Your profile says it is a “home made” machine. Did the machine work and this is a new problem?
Are there any alarm messages, or can you continue to Jog with the X- button?
yes, I replaced it and it worked, but after a few tests, the same problem occurred.
I don’t get any alarm messages and when the + or - buttons are clicked, the x axis only moves to the right while the y axis works perfectly in both directions and the laser head also switches perfectly.
My first step would be to check the connections from the driver to the stepper motor. It sounds as though the two Step wires are connected ok, but one or both of the Direction wires are not.
Read through this.
stepper motor move only in one direction · Issue #137 · makerbase-mks/MKS-Robin-E3-E3D · GitHub
thank you
i see this and good
