HELP! I may have smoked my laser. (GWeike lc6090/Ruida RDC6442S)
Y settings could be completely different because of the mass it’s moving. My Y is about 6 to 8,000mm/s^2, the X axes is 45,000mm/s^2. This is because the head only weighs 100 grams. But it was a similar difference before I got under the hood.
:grinning_cat:
The ones I have too, although the motors and drivers are equal and as to test if they are ok should work with the same settings.
So I did confirm that X driver is two-phase and the Y driver is three-phase. I rebooted this morning to look for any sign of error lights and found something interesting. As of the last reboot I have regained control of the X,Y and Z motion when controlled through the control panel. The Y axis is still very slow and only advances about 3" total (of about 24" normally). The only variable I am aware of is this time the PC was not connected to the laser. I have considered ordering a cheap oscilloscope to see if I can determine how many pulses are originating from the controller. I have no record of the original settings in the software but I have no idea how these could have gotten changed anyway. So, 1-The Y stepper motor was disconnected during the event - it should not be damaged. 2-The Y stepper driver has been replaced. 3-Wiring has been inspected for signs of heat or damage (terminals and as much as visable) 4-No settings have been changed. 5-There may be a correlation between the PC being connected or not (I will retest that tonight). Does any of this make sense? I see about 4 power supplies that I can test, other than playing with software settings or replacing the controller I don’t know whats left. Any more suggestions?
I live in rural east Tennessee so there is no option for a technician to service this. Is there any place I could send the controller to for inspection?
Before you do much more. I’d download the controller settings and save them while it’s still working. Just incase the controller is on it’s way out you have a backup.
NICE! That’s a great idea. Thank you.
FNIRSI DSO152 Handheld Oscilloscope 200kHz Bandwidth
$38 Amazon
Before buying a scope, there’s a quick swap test that isolates the Ruida from the driver/motor side:
  1. Power off. On the Ruida, unplug the Y axis signal cable (PUL/DIR/EN) and plug it into the Z or U axis port instead, if you have a free one. Then jog that axis from the panel. If the Y motor now moves the full, correct distance, the Ruida’s Y output channel is the problem. If it’s still slow and short, the controller is fine and it’s the driver or its settings.
  2. Since the replacement driver is a different model than the original, compare the pulses/rev DIP table printed on both drivers, not just the switch positions. Same switch positions on two different 3-phase drivers often mean different microstep values. Moving roughly 1/10 of the distance is exactly what a microstep mismatch looks like.
  3. Also check Vendor Settings → Y axis → Step length in LightBurn (Edit → Machine Settings). It’s in the same family of symptoms. And as micrololin said, save a backup of the settings first.
In my experience repairing these, the Ruida pulse outputs very rarely die from a motor-side fault; the driver takes the hit. So I’d bet on step 2.
The replacement Y stepper driver is identical to the original. I have documented all the parameter settings and I have also reached out to the manufacturer for the original settings so I can compare as soon as I hear back. I would like to attempt to swap the signal cable from the Y to the Z driver as these are the same but I’m not sure on the procedure. If I power down to do the swap and leave the Z disconnected, the machine is going to want to attempt to home on startup. If the Y driver is disconnected there would be no gantry movoment to home. I’m not sure the machine would allow any motion testing until it completes it homing sequence.
If you don’t shut off the power to the driver, disconnecting the motor can very easily destroy the driver.
You could disconnect the power wires to the driver(s), leaving the rest of the machine turned on, swap motors as needed, plug the driver power in again, and (ideally) the controller wouldn’t know the difference.
To repeat: do not unplug the motors from their drivers with the power on.
Stipulated: @jkwilborn has done that over the years for different motors & drivers with no ill effects. Other folks, myself included, come down firmly on the “how many drivers can you afford?” side. :grin:
I might have missed it. Have you used a miltimeter and checked input voltage? Just because it’s getting voltage it might not be getting good voltage.
That was good incite, I had not checked voltages previously and there are about 4 different power supplies. I took a minute and checked them all and everything seems to be putting out proper voltages. I started documenting all of the machine parameters so I can restore to a point but I don’t have a benchmark from before the incident. I don’t know how those could have changed but I’m trying to cover my bases. I have reached out twice to GWeike laser last week and still have not gotten any response. Unexplaned thing are happining that are causing me to suspect I have a ghost in the controller. Initially after booting up I could not control and XYorZ motion through the control pad. I could get normal movement on X and Z when requested through Lightburn. After several reboots I found the laser did respond to the control panel although very slow and limited Y movement. Upon retesting , I found when I request a 100mm jog of the Y axis on Lightburn I get a very slow movement of about 14mm but the X axis laser head travels simultaneously to the extreme right limit. These things shouldn’t be changing so now I suspect I may need to start with replacing the controller.
Translation: A power supply with no load, which the meter is, can have a correct output. But under load, where it has to deliver near the rated current, the output voltage can drop to unacceptable levels.
This can cause the controller to produce errors in positioning or laser output control. Validate the power supply outputs before investing in a new controller board, or ghost zapper.
