Help! LightburnTracing Issue
Hi! I’m having issues tracing the hand, toes, and shirt of the surfer in this image. Everything else seems to trace fine. Any ideas or help is greatly appreciated!
Hi Annmarie
What I do is select Trace transparency if no other option will work (such as adjusting the values using sliders), this should give you a trace line right around the outside of the image.
If by chance the Trace ends up with also an outer frame (rectangle)..you can Pess ok and then Ungroup the Trace of the image and the outer rectangle and then Delete the Rectangle…leaving you with the Trace of the image.
If you dont want to trace the whole image you could try using ‘Boundry’ which you can find out about in Lightburn Documentation’ if you go to Doc’s and type in Trace Image.
I havent used Boundry yet but it may suit your needs.
After Tracing then you can put a shape around the outside of your trace by using the (Offset Shape Tool) and this will give you a line right around the image.
You can Group the two or put them on the same layer…to keep them together.
Hope I said that correctly! but if your not sure just go to Doc’s and have a look.
