Help me properly set up and edit an array and ........snapping?
Can you guys explain the difference between and array and a virtual array. I think the documentation is bit old. I am importing a shape and using an array to make blocks. See file. Problem: I can’t edit the array if I need to. When I try the virtual array every block but the original is black and I can’t seem to select them when I finish building the array to move them. Am I missing something?
sidewalk v12 cobblestones.lbrn2 (1.1 MB)
On the file you uploaded I can click each individual shape and move it as needed. Guess I’m not seeing what you’re seeing.
