I am looking to purchase a large-format CO2 laser marking machine. Could you please recommend the best, most reliable machine that delivers outstanding results? Our primary application will be engraving and texturing designer elevator cabins.
Hello and welcome!
I can’t help because I’ve never worked with those machines.
Still, I know that experience is necessary to achieve what you aspire. No machine can do everything on its own to obtain your desired result.
In my opinion, regardless of the machine you buy, you will need to find the ideal settings for the materials you intend to work with to obtain the result you consider outstanding.
The most reliable usually involves an RF source. Commercially built machines are commonly used when reliability and precision is needed. Of course, these cost big bucks.
Most people upgrade from the standard Chinese model, I changed the head and transport mechanics on my co2.
Thunder, in the Pacific NW in the USA builds an assembled in America from Chinese parts laser that would likely be a good fit. They are slowly converting to RF type sources, instead of tubes, as they are generally more dependable.
If I had to do it again, I would have got one of the 70W Cloudray Russ spec machines. This video is the development of the spec machine. He has a good relationship with Cloudray owner. They have all the upgrades plus some, but I don’t see them advertised on the Cloudray site anymore.
This is a photo from the Alibaba site, Cloudray used to sell them with chiller and all for about $4K.
Notice the head and belt drive are a vast improvement to the normal head/drive system.
Head an drive system look like this. From my machines.
A good Coherent/Lumenis RF laser is by far the best. Commercial mfgs don’t get into them, but you can make a hotrod out of a takeout.
Once you have a powerful, fast-responding laser source, then it becomes of very high value to get a fast-accelerating head. That’s a complex subject.
I do strongly recommend external U-bearing rails (Lightobject has one good type, “CCM” is a good search term to see the type I’m talking about). This stuff can greatly outperform the ubiquitous Hiwin linear rails 99% of lasers use.
