why does my atomstack stop when it is in the engraving process???
I have already made several attempts and it tells me that the transfer failed.
Have you done a search through the forums? This is an extremely common issue. Suggest you work through them and see what might make sense for you and then circle back after you’ve reviewed and assessed the situation.
Which Atomstack engraver do you have? Are you using a short, shielded, high quality USB cable with the ferrite beads?
Please tell me more about ‘transfer failed’. I’d like to know if you’re seeing this in LightBurn and in which window and if there is any other text around this.
