I request help from the community, I am new to the subject of these devices, I have a copy whose reference is • 15000 mw Blue CNC Laser Engraving Machine 40X40, the lens does not respond to movement commands, I request help to solve this problem, thanks for the information they can share.
A link is much more useful, there are a million of these with the same description out there. Which one do you have?
Need to clarify what you mean here… is the laser head not moving or do you have a Z control that isn’t working? Or is this an optical problem?
Thanks for answering, the problem is the area of movement, it is very limited, the laser beam works fine, when I activate the area tracking commands, the result is very limited.
Have you ensured that Lightburn and the machine are set to the same units, mm or inches?
