Help to solve the problem of the non-metal co2 laser machine
Hi, I have a metal laser cutting machine, the main board is N6442, I use it with RDWork program. When I set the head to cut and set the starting point as the origin, the cutting nozzle does not return to the origin point. I mean, when I cut the nozzle at a point and set the origin option on the main board, the cutting does not return to the origin point, and when I press the red esc button on the main board, it does not return. Can you tell me what to do? If you can help me to solve my problem, I will be very grateful. Thank you.
Hi @Mehrdad
Are you asking about where the job starts from, or where the head returns after the job finishes?
In RDWorks, check the Position setting in the Laser Work panel.
That is the rough equivalent of LightBurn’s Start From mode. If you want the job to use the point you set with the controller’s Origin button, use the Anchor Point option, not absolute coordinates.
If the issue is only that the head does not return after cutting, check the controller/RDWorks Return Position setting instead. That controls where the head stops after the job finishes.
It is just Chinglish that they use anchor point.
That makes me question what’s the difference between machine zero and absolute coordinate?
I don’t run RDWorks as I don’t use Windows.
:grinning_cat:
